M800 Outputs error, been burned???
The engine we have is CBR600RR. After the wiring stuffs, I connected all the sensors and IGN1(Coil and spark plug), remain the IGN2,3,4, INJ1,2,3,4, fuel pump, fan and so on disconnected. Then used the starter to rotate the engine. I did this to calibrate the CRIP with a timing light. At first, everything is fine and I did see the flash lights. I also got a capture of the ref/sync signal. But, when I retried the third time. I couldn't see the flash lights. Then I noticed that the coil was so heat!
Of course I disconnected the coil immediately. From then on, when a coil connected to the IGN1 output pins, it would be heated. But remain normal when connected to the IGN2,3,4 output pins. Since I don't have a oscilloscope at hand, I used a digtal multimeter to check the voltage between the two pins of IGN. I found that the voltage between the two pins of ING1 was about 12V, and the voltage between the two pins of ING2,3,4 were about 8.5V. Also, when testing outputs with Motec ECU Manager. The voltage between the two pins of ING1 remained the same when testing or not. But the voltage between the two pins of ING2,3,4 changed slightly when testing or not.
What's the problem? Does it mean that I burned the IGN1 port? How can I burned it? Everything operation seems to be no problem.
What can I do now? It's really urgent......
