What's the problem? Does it mean that I burned the IGN1 port? How can I burned it? Everything operation seems to be no problem.
What can I do now? It's really urgent......
Martin wrote:Have you got the trigger edge correct for you IGN system?
Also, some coils, if they have power while the ECU is off they trigger, couldnt that be the reason for the hot coil?
Another thing you can check is that your "Number of coils" is correct.
IDP wrote:You should not connect the CBR Coils directly to the IGN outputs of the ECU.
They must be connected to an ignition driver first.
thorstengsxr wrote:HI
I konw it's a hard information for you, but IDP gif you the correct information. The CBR 600 RR has Denso coils and you need a wirring like this.
http://www.motec.com.au/filedownload.php/m37.pdf?docid=1267
regards Thorsten
http://www.racebikesonline.de
formulauem wrote:Hello!!! I´m a in a formula student team and we´ve recently purchased a Motec M800. We have set a CBR 600 RR engine and i have a couple of doubts:
First of all I would like to know if I have to connect the coils direcctly to the ignition outputs or put a ignition module between them.
Secondly, has someone any start file or base map for this kind of engine and motec? I will appreciate it very much.
Also i don´t know if just with the serial port (Tx, Rx, 0V) and an USB adaptor I can connect the motec with my laptop.
Kind regards.
Thankyou very much.
http://www.formulauem.es
