Ignition interfereance issues
Hi all,
I'm having some problems with the ignition set up on my track car, its a 1992 Subaru Legacy RS Turbo with a 2.2L Cosworth Stroker Motor and assorted other goodies.
The problem i'm having is I have changed my ignition setup to run LS2 Chev coils to get a stronger spark and am getting big misfire's. I have an M800 Gold Box and there are no ref/sync errors and the CRIP is fine. I have used the recommended settings for dwell from MoTeC support and have tried going from well lower to well higher dwell with no change in result.
I have been told it could be related to the type of ignition leads I'm using as some leads suffer interference when run on MoTeC and other ecu's. I am using Spiral Wound Ignition leads, made to length by a local manufacturer here in Perth, WA.
I have been told that I may need to run basic straight (non-spiral) leads or look for a shielded type lead???
Has anyone ran into these issues previously and if so how was it resolved?
Any info would be greatly appreciated, as I have a circuit event coming up soon and need to sort it out!
Cheers,
Rob
PROTOTYPE
Cheers,
Rob
PROTOTYPE
