Hi-LO Injection M800-Running E85
Im thinking of running E85 fuel ...As you would know this would require a lot more fuel flow
The setup at the moment is Lo-Hi
280cc-300cc = Primary injectors x 4
1000cc=Secondary injectors x 4
The balance table turns them off and on as you would know
There are other settings to set the turn on and off points for primary and secondary ..
im hoping these settings will allow me to leave the primary injectors on and phase in the
secondary injectors to take advantage of the extra fuel flow ,so all 8 injectors are
working when at high boost running e85 fuel .
Is this possible or are there limitations to Hi-lo Setups ..?
