Use PWM on a M400 to control an electromagnetic clutch
Hello
I am trying to use an electromagnetic clutch on a prototype for the Shell Eco Marathon. I control the clutch voltage with a PWM auxilary output links to a MOSFET transistor. The settings for the output are now 5kHz frequency, 0 minimum duty cycle and 100 maximum duty cycle.
The problem is that when I test the Motec output voltage there is no voltage between 0 and 50% and 12V between 51% and 100%.
What is the solution to have a progressive voltage ?
