Knock signal logging newbie
I have a M800 and have fitted a J&S safeguard unit .
This is a gated device using ECU triggers and has individual closed loop knock control .
I would have preferred the SKM to keep it all Motec but I could not justify the price.
Just want to protect my big $ engine against the unexpected.
I would really appreciate some help on setting up and data logging the output data signal from the J&S unit which is a maximum of 1.3vdc in 10 x 0.13v steps.
I can set up a user defined custom table 11 x 2 resolution starting at 0v for 0, 1 for 0.13v , 2 for 0.26v etc with a 200hz sampling rate.
Can I set it up in Adjust/sensor setup/input setup/other/knock voltage- input source AV4 with a custom table as above.
How do I activate it from here ...??
I want to data log this against O2, rpm ,TP, Boost, Ignition Advance etc so I can road tune it better and basically am a very eager amateur.
Any tips on setting this up would be greatly appreciated.
Mike
Mike
