Using CAM position as Z parameter for 4D tables
How do I configure the ECU Manager to use the CAM position (on Dig1) as the Z parameter for the 4D fuel and ignition tables? -- I see how to setup the tables to use values from USER1, and can enter cam angles into the Z sites -- but how do I specify the input for the axis should come from Cam Pos Inlet (CamIn)?
