Using CAM position as Z parameter for 4D tables
Postby David Ferguson on Mon Mar 07, 2011 12:45 am
How do I configure the ECU Manager to use the CAM position (on Dig1) as the Z parameter for the 4D fuel and ignition tables? -- I see how to setup the tables to use values from USER1, and can enter cam angles into the Z sites -- but how do I specify the input for the axis should come from Cam Pos Inlet (CamIn)?
Re: Using CAM position as Z parameter for 4D tables
Postby TunedByShaneT on Tue Mar 08, 2011 3:42 pm
David,
there are a couple of methods for this. email me and I will tell you what you want to know.
Regards,
Shane Tecklenburg
Technical Consultant
ST Consulting
21602 Surveyor Circle
Huntington Beach, CA 92646
714-318-5845
shaneteck@yahoo.com
TunedByShaneT
