Honda K20A i-VTEC CAM control
I'm wiring up an M400 to a Honda K20A, and am looking for any advice or information about the following:
-- Details on the Honda K20A coil-on-plug -- do they have ignitors built in, or do I need to wire in an ignitor?
-- The i-VTEC has two cam controls -- first is a high/low lift cam control that is activated by a solenoid control. I assume I can control this with an auxiliary output, and base it's activation on a LOAD/RPM table? Any other clues as to how I can add hysteresis so that it activates at one RPM, and deactivates at a lower RPM?
-- The second intake cam control is what I assume the Cam Control option is going to allow me to use. It looks like I connect the Intake Cam Sensor to one of the digital inputs, and assign that the function of "Cam Position (type 1)", then I use an auxillary output for function "Cam Control 1". Then I tune using a table to define the Cam position I want based on my table inputs, and the M400 will try to achieve my target timing on the Cam Position, by varying the output pulse width. Is this correct? Is there any application note or documentation on any of this?
-- Does anyone use the standard Honda Knock Sensor to retard timing at various voltage levels? -- or is this just outside the M400 capabilities?
-- Does anyone have sensor calibration for the stock Honda Temp & MAP sensors?
Thanks in advance for any help.
