Possible warnings in Motec ECU Manager
Postby LacknL on Fri Feb 04, 2011 4:58 am
Hey Guy's!
I have a question regarding to the possible warnings in the ECU Manager.
We run an engine on the testbed but sometimes a short information appears ... I only could read Motec Traction Control!
I believe the design of the window was in the typical windows warning design.
Does somebody know what I mean :)
Kind Regards
Luke
LacknL
Re: Possible warnings in Motec ECU Manager
Postby SprinterTRD on Fri Feb 04, 2011 7:12 am
The warning means that Traction control parameters has been met and TC is active.
You should probably de activate it if you are tuning the engine.
