Doing a Custom Loom
Hello Everyone,
After much thought we decided to tackle the custom loom issue in-house. We believe the experience will benefit our company in the long term. Our current project is:
ECU: M800
Motor: 2UZE Tundra FI (40psi max)
Transmission: 6 Speed Manual
Chassis: Lexus SC400
We have the engine harnesses for both cars and will graft the require 2UZ wiring onto the SC400.
The logical place for us to start are with the sensors:
* 4 Bar Map Sensor (for map)
* 1 bar Map Sensor (for baro)
* Bosch Engine oil pressure sensor
* Engine oil temperature sensor
* Fuel pressure sensor
* Inlet air temperature sensor
* Lambda Sensors x2
Do we really need crank and cam sensors?
Pyros for individual cylinder measurement:
8 Thermocouple probes
Plugs:
* Bosch engine oil temperature sensor plug
* Bosch injector plugs x8
* ECU Header Pin Kit
Mounts:
Panel mount socket for UTC
Switches
* Motec 10 poisition switch (for boost adjust)
* Motec 4 position switch (for configuration switching)
If you could please provide us with motec product codes and where to purchase so we could
start as soon as possible. Also, please let us know if we are missing any sensors, plugs, mounts etc..
Also the correct wiring we should for the loom, and any other tools needed for the project i.e. crimpers,
extraction tool etc..
We've never done a custom loom before, but believe the first few times will be short time pain for
long time gain.
Your help is greatly appreciated,
Ninus
ECU: M800
* Lambda Sensors x2
Plugs:
Mounts:
Switches
long time gain.
Ninus
