ZX12R (`02) CRIP
ZX12R (`02) CRIP
Postby matlech on Fri Jan 14, 2011 12:06 am
Hello Everybody,
I work on a Kawasaki ZX12R (`02) with a MoTeC M400.
The only thing I´m not sure about at the moment is the CRIP.
I opened the crank wheel cover and made some pictures.
I hope you can help me.
The first picture shows the crank wheel at the TDC Position of Cyl. 1:
This picture shows the crank wheel at the point where the cam tooth is at the cam sensor:
In this picture you see some angles I know:
The tooth marked with "i" is the one I think to be the index tooth.
Regards,
Matthias
matlech
Re: ZX12R (`02) CRIP
Postby Mika on Sat Jan 15, 2011 4:35 am
Try 460
Mika
Mika
Postby insomnia on Mon Jan 17, 2011 8:15 am
For CRiP best to read the help file in the software...
The CRiP on each bike will be different as the sync tooth is on the other camshaft and a different position, it happens all the time with different engines, same maker.
insomnia
