Frequency valve to PID boost control
Postby uvii on Sun Jan 09, 2011 5:29 am
Is there an easy way to convert a simple boost control frequency valve vector to PID control?
uvii
Re: Frequency valve to PID boost control
Postby MarkMc on Mon Jan 10, 2011 3:30 pm
Basic answer, no.
The PID values are what will ultimately control the boost and they are specific to the whole mechanical set up. What you really must do is work out the open loop settings first as these become the starting point of your closed loop, i.e. the Normal Position table for the closed loop is the Duty Cycle table you use for open loop.
Not really sure what a "frequency valve vector" is, I assume you mean the duty cycle table.
