communication cable with parallel DIY
Postby yotamhks on Wed Dec 22, 2010 9:51 am
hello everyone,
is this possible to build my own communication cable from parallel directly into ecu?
if so, can someone suplly the wiring diagram for it (inside of the parallel connector, to ecu i know what to connect)
thanks
yotam
yotamhks
Re: communication cable with parallel DIY
Postby MarkMc on Wed Dec 22, 2010 3:37 pm
Basically the answer is no, there would be a fair bit of MoTeC IP that would be needed to make it work and I boubt there is any chance of it being released to the public.
Postby yotamhks on Wed Dec 22, 2010 9:14 pm
OK thank you.
i have a rs232 motec ecu cable, does it help?
yotamhks
Postby MarkMc on Thu Dec 23, 2010 3:14 pm
The hundred series ECUs only communicate with the laptop through CAN so you either need a CAN cable or the newer USB to CAN (UTC) cable. There is no option to talk between the laptop and ECU with RS232.
Postby jasaircraft on Sat May 14, 2011 4:27 pm
is it possible to make you own can cable? like go to the precise pins on the board and even better just make the other end a usb plug for your laptop?
jasaircraft
Postby NathanS on Sat May 21, 2011 5:06 am
As Mark mentioned a lot of MoTeC IP would be required to make your own CAN cable or UTC and basically this isn't going to be released.
Sorry guys you're going to have to bite the bullit and buy the appropriate comms cable.
NathanS
Postby jasaircraft on Sat Mar 16, 2013 2:56 am
Heheheeee I think we can buy an universal USB-CAN convertor ;) (obviously wiring in the right order the CANHi, Lo and gnd cables)
jasaircraft
