Ls2 map sensor calabration
Hi all
I am running a Ls2 with a M800 and are having problems with the MAP sensor.Its the stock one and at the moment
i have it set up as a delco 100kpa.I know this must be wrong as i am getting a error sometimes and its doing silly things when i pull the logging after a run.
Has anyone run a STD Ls2 MAP sensor?
Thanks For you help
Daniel
Thanks For you help
Daniel
