How to trace error group values
Postby ElsmoortelG on Wed Jul 09, 2008 10:54 pm
What is the meaning of value 16 in the M800 Err Grp 1 ?
What is the meaning of value 16,32,50,160,162,176,178 in the M800 Err Grp 14 ?
In the help file is mentioned :
It may require the knowledge of which Bit and/or Bitmask represents the item. Then there is a table which mentiones : Error Group Item, Bit, Bitmask
Each group contains 8 different items but I can not figure out how the above values refer to one item of the group.
Can somebody explain ?
ElsmoortelG
Re: How to trace error group values
Postby DarrenR on Thu Jul 10, 2008 10:13 am
Welcome ElsmoortelG
Each error/status is assigned a value that represents each bit of the error group channel 1, 2, 4, 8, 16, 32, 64, 128
If there are multiple error/statuses on at the same time these numbers add together, so when the error group has a value of 50, that is error 32, 16 and 2.
A bit mask works by filtering the channel so only certain bits have an effect. A bit mask of 50 allows error 32, 16 and 2 to change the result to their corresponding values but any other bits are masked so if bit value 1, 4, 8, 64 or 128 appears they do not affect the result.
What each bit means can be found in the ECU Manager help when veiwing the logging setup for the error groups set out with values as follows.
Code: Select all
Error Group 1                                 decimal      hex      binary
   Throttle Position Sensor                   1            01       00000001
   Manifold Pressure Sensor                   2            02       00000010
   Inlet Air Temperature Sensor               4            04       00000100
   Engine Temperature Sensor                  8            08       00001000
   Lambda Sensor 1                            16           10       00010000
   Lambda Sensor 2                            32           20       00100000
   Exhaust Manifold Pressure Sensor           64           40       01000000
   Mass Air Flow Sensor                       128          80       10000000
Darren Reynolds
DarrenR
Postby ElsmoortelG on Thu Jul 10, 2008 4:49 pm
Thanks Darren.
ElsmoortelG
Postby thorstengsxr on Sat Jul 26, 2008 4:51 am
Hi
Has aynbody a documatatin about die bits of each error and status group?
I want to dislay the for me importent errors and statuts informations on my ADL2.
regards
Thorsten
thorstengsxr
