Dual rpm error window
PostPosted: Mon Nov 01, 2010 3:23 am
by Wolf_Tm250
anytime I press the clutch and hit dual rpm limit, I get an error window on my Car-PC that stays there until i press "OK" in the window:
any idea how not to get this error window anytime I am in those conditions?
Thank you.
Re: Dual rpm error window
PostPosted: Mon Nov 01, 2010 8:22 pm
by SprinterTRD
The error is displayed because dual rpm is active and you shouldn't tune a engine when it is active.
PostPosted: Tue Nov 02, 2010 3:29 am
by Wolf_Tm250
SprinterTRD wrote:The error is displayed because dual rpm is active and you shouldn't tune a engine when it is active.
Ok thanks, makes sense.
So is there any way to remove this warning?
Thanks.
PostPosted: Tue Nov 02, 2010 8:15 pm
by SprinterTRD
Yep, don't activate the dual rpm rev limit when you have the laptop connected!
PostPosted: Tue Nov 02, 2010 11:52 pm
by Wolf_Tm250
SprinterTRD wrote:Yep, don't activate the dual rpm rev limit when you have the laptop connected!
Unfortunately this is not a solution...
I built a m400 permanent connected car-pc to have in dash gauges, so my "laptop" is always connected...
Wolf
PostPosted: Wed Nov 03, 2010 3:12 pm
by SprinterTRD
I would sat that the warning is hard coded into the PC tuning software.
The only way to get around it is to possibly get the Telematry upgrade and use Telematry monitor for your display instead of the Tuning software.
PostPosted: Thu Nov 04, 2010 5:05 am
by Wolf_Tm250
SprinterTRD wrote:I would sat that the warning is hard coded into the PC tuning software.
Ohh thanks!
Didn't thought about this opportunity...
Wolf
