Ref/sync suggestions (NEED HELP)
I have started my project (nightmare) and hitting some brick walls.
1982 Ferrari 308 GTSi. Converting to COP and SMFI via M800. The problem that I'm having is trying to understand and resolve my ignition issue. The 308 has a pick up at the flywheel to check the engine speed and position. Dual distributors controlled by Magneti Marelli Digiplex MED801A. I guess the flywheel could be used as a reference?? What's the best way to provide the 800 with the sync signal to make it work?
Any suggestions will be greatly appreciated.
