injector settings
hi all,
am changing to higher capacity injectors and thus have to use low impedance injectors compared to stock high impedance ones. Can i confirm that the main things to change would be the injector setting page esp the current and peak ratio?
however, the sard 1000cc injectors dont come with peak current values so how do i know and set the current of the injectors in the m800 setting page when the injector is not listed in the help file as well?
thanks
thanks
