injector settings
injector settings
Postby C4a0s on Fri Sep 03, 2010 2:30 pm
hi all,
am changing to higher capacity injectors and thus have to use low impedance injectors compared to stock high impedance ones. Can i confirm that the main things to change would be the injector setting page esp the current and peak ratio?
however, the sard 1000cc injectors dont come with peak current values so how do i know and set the current of the injectors in the m800 setting page when the injector is not listed in the help file as well?
thanks
C4a0s
Re: injector settings
Postby MarkMc on Fri Sep 03, 2010 4:54 pm
The peak current is usually tested by us. Can you give me the part number for the injector and the resistance across the two pins please.
Postby C4a0s on Fri Sep 03, 2010 6:04 pm
the part number is #63518. I dont have the resistance cos i havent bought the injector yet. Want to be sure before i spend the $ on the injectors.
C4a0s
Postby C4a0s on Sat Oct 30, 2010 4:57 pm
I've gotten the injectors, the resistance across all 4 are the same, 2.5ohm. Anyone knows how to set it up in the M800? I'm currently using high imp sard 550cc/min injectors. The new ones are 1000cc/min, Sard part number #63518
thanks
C4a0s
Postby C4a0s on Sun Nov 07, 2010 12:24 pm
anyone knows how to set up the low imp injectors?
C4a0s
Postby C4a0s on Tue Nov 09, 2010 4:09 am
no one?
C4a0s
Postby C4a0s on Wed Nov 10, 2010 11:18 am
just found out that the Denso part number is #195500-3650
C4a0s
Users browsing this forum: Baidu [Spider] and 26 guests
