RSV4 Coil setup
RSV4 Coil setup
Postby Fast_Moto on Tue Aug 24, 2010 8:30 am
I am in the process of setting up a Motec system for the Aprilia RSV4. In my past experience, the stick coils required an external ignitor. The RSV4 stick coils, however, have three inputs: +VBatt, secondary circuit to ground, and an activation signal. Does this mean that no ignitor is required to operate these coils using a Motec M880? I have attached a coild wiring diagram and excerpt of the service manual in case that helps.
RSV4 coils.jpg (95.14 KiB) Viewed 11210 times
RSV4 Excerpt regarding coils.pdf
(69.56 KiB) Downloaded 1264 times
Fast_Moto
Re: RSV4 Coil setup
Postby Polux RSV on Wed Aug 25, 2010 2:16 am
From the picture, I would say amplifier is integrated on top of coil stick. But I could be wrong. With an Ohm-meter, check drive input resistance to ground and +12V. If you find very low ohms to 12V, it means they are classic coils and you need an ignition driver. If you find high ohms to ground, drivers are probably integrated to the stick.
Nice project. A M800 is also driving my RSV, but a 1060 V2 :mrgreen:
Angelo
Polux RSV
Re: RSV4 Coil setup
Postby Fast_Moto on Wed Aug 25, 2010 8:01 am
Thank you. I will try your suggestion.
Fast_Moto
Re: RSV4 Coil setup
Postby Paul M on Thu Aug 26, 2010 10:22 pm
I have used these coils on a RSV4 superbike and you will need a module,
Cheers Paul
Paul M
Re: RSV4 Coil setup
Postby Fast_Moto on Fri Aug 27, 2010 1:41 am
Thanks. Did you connect the outputs from the ignition module to the activation signal inputs on the coil?
Fast_Moto
Re: RSV4 Coil setup
Postby Paul M on Mon Aug 30, 2010 8:29 am
Hi, on the STD coils: Pin 1 12v, Pin 2 Gnd, Pin 3 module input.
Cheers Paul
Paul M
Users browsing this forum: No registered users and 73 guests
