Adding voltage based gear selection indication?
I have M800 in a RWD Skyline chassis, using a Swedish Tractive sequential gearbox. This came with a display indicating the selected gear on a panel. This is computed from the voltage output of a pot on the selector barrel shaft. Can I ALSO use this output to tell the M800 what gear the transmission is in, and how please?
Given that I can tell the M800 what gear it's in, can I go further and create some sort of table whereby the ecu can log road speed? I don't have any wheel speed sensors, it would need computing from engine RPM, gear selected and diff ratio and tyre rolling circumference. I am going to put the running gear in a new shell soon, and will then have all 4 wheels monitored for speed, and I hope to then add traction control, but for logging purposes right now a road speed and gear indication would be very useful. Thanks.
