Page 1 of 2
M800 Injector timer output
Thu Aug 19, 2010 8:51 am
by 20B
Ok here is a tricky one for the experts !
Is it possible to have Inj output 7 switch on then off lets say every 8 seconds continually but only when the rpm is above 500 rpm and the engine temperature is above a certain point ?
Could this be done on the ECU or is this SDL / ADL territory ?
Re: M800 Injector timer output
Thu Aug 19, 2010 1:06 pm
by SprinterTRD
Call it a intercooler spray bar and its done.
Fri Aug 20, 2010 1:41 am
by Martin
I dont think the spraybar funtion will listen to engine temp...maybe run it in your SDL, think it will be easier there with 2 timers.
Fri Aug 20, 2010 8:34 am
by SprinterTRD
You can do it if you feed the spray bar function output into a input on the ECU. Then use that input channel on a axis of a user defined table with temp as the other axis on another AUX output which controls the injector.
Fri Aug 20, 2010 12:58 pm
by Sander
Thats pretty clever sprinter. Cool idea.
Sat Aug 21, 2010 3:03 am
by Martin
Ohh now I understand how you would do it
Or just use the Sparybar output`s DC as one axis on the Aux table instead of wiring
Sat Aug 21, 2010 11:48 am
by 20B
Care to show how it would be done ?
Sun Aug 22, 2010 6:30 am
by Scott@FP
When you go into the table axis setup, hit the 'select' bar, when it pops up check the 'show non-sensor channels' box and all kinds of wonderful possibilities for experimentation occur. All the aux inj ign DC's can be an axis among many other things.
Sun Aug 22, 2010 12:42 pm
by 20B
Wow I never really ever noticed that sneaky little checkbox ! Lots of goodies in there to play with.
I'm still a bit unsure of how to set it up, can anyone do a quick screengrab of the table settings you would use to make INJ output turn on then off continually for a given time above a predetermined engine temp ?
Tue Aug 24, 2010 2:17 pm
by Scott@FP
function 102 thermo fan might do what you want, except the lowest frequency appears to be 1 Hz. Then you can set up its table to 1 or 2 axis operation.
