Injector current setup
Postby Polux RSV on Tue Aug 17, 2010 8:34 am
What will happend if I set the current too low in General setup->fuel->setup ????
Is it possible the injector will not completely open, resulting in lower fuel flow ?????
Angelo
Polux RSV
Re: Injector current setup
Postby Polux RSV on Thu Aug 19, 2010 8:35 pm
No Motec guy to explain if injectors are current limited or only PWM driven ?
Angelo
Polux RSV
Postby SprinterTRD on Thu Aug 19, 2010 9:09 pm
You answered your own question!
The fuel flow will not be consistent as the hold current may not keep the injector open.
Postby Polux RSV on Fri Aug 20, 2010 1:38 am
Thanks. I suspected this behaviour because changing values in fuel tables had no effect on lambda readings.
But as an electronics engineer, I still would like to know if the injectors outputs use FET transistors with PWM, or transistors with programmable current limiter :mrgreen:
Angelo
Polux RSV
Postby SprinterTRD on Fri Aug 20, 2010 8:28 am
If you scope the injector output you will see how the current limiting is done.
Postby Mazi on Mon Aug 23, 2010 10:12 am
Mazi
Postby Polux RSV on Mon Aug 23, 2010 9:13 pm
Thanks Mazi, exactly what I needed to understand parameters meaning. :mrgreen:
Angelo
Polux RSV
Users browsing this forum: Google [Bot] and 11 guests
