Data file, troble with PLM readings.
Would someone kindly have a peek at my logging file taken at Oulton park from my RB26 engined RWD Skyline please? I am happy with the mapping, it has done several track days with no issues. I run dual wide band Lambda, one is read hard wired to the M800, the other via CanBus from my PLM. On Saturday the PLM started to show Lambda of over one at times, which it has only done before when I lost an ignition igniter output and the engine was on 5 cylinders. I THOUGHT I had logging set to record both sensors, but my mapper who did some map trimming last time out may have reset logging to suit his needs at the time, so I am unsure if I am reading the log incorrectly or not. It seems to show Lambda 2 as an error in the right hand column. I believe Lambda 2 is the sensor on the PLM, and Lambda 1 is the sensor that the M800 reds directly and is used on its own for the map trim? The log for Lambda 1 seems, to me, to be showing safe and sensible O2 levels, which is good. So, finally, my questions are, is there a fault with Lambda 1 sensor? Should I try re calibrating it? Or is the data logging set incorrectly to show this area of functionality? I am happy to post the map if needed. thanks. http://www.gatesgarth.com/oulton.zip
