Primary/Seconday injectors setup
I have two injectors per cylinders on my bike, one spraying in the manifold, the other spraying on top of the butterfly.
Both are not oversized and I would like a setup were at low rpms or load, only the manifold injector is used. Then gradually, both are used, and at full throttle, only the secondary is spraying.
I understood the secondary balance table, but not the primary/secondary balance on/off parameters. Which values should I use so injectors works as I want? Can I put 0.0 in Primary parameters and 100% in Secondary?
Thanks for a better explanation than help screen, often not simple for a non english speaking guy.
Angelo
Angelo
