Lean Spool
Engine leans out on turbo spooling up when running at 90-100% throttle.
Mapped lower loads with more or less steady constant load ok, however once started to map full throttle loads of 200 kpa and above keep getting lean lambda during turbo spool. The engine is Subaru STI 2.5 with Cosworth heads, 260-11.3 custom cams,Cosworth intake manifold, Greddy TD06 20G turbo, 4-1 exhaust manifold. Usually THxRPM fuel comp map used to solve the issue with few % added in the turbo spool rpm range (2000-4000 rpm), but not this time.
Screen shot below already has increased accell comp and +15% at 100% TH, but doesn't solve the problem, just some parts got richer.
Which comp strategy would be best suited for this case?
Best regards
Alex
Best regards
Alex
