Bosch 0 227 100 211
I would like some help if possible, I have a Turbo Suzuki Hayabusa running M400, the bike has had the same turbo kit for 3 years and I have been running MOTEC M400 on the bike for the past 18 month’s. I am part of a race team, we run 3 bikes of similar spec, the 3 bikes are running Bosch 044 fuel pumps, Bosch 750cc injectors and the same ignition modules
The 3 bikes over winter were stripped and rebuilt, 2 of the 3 bikes have run like clock work but my bike has been burning the barrel between cylinders 2 and 3 at low levels of boost, less than 1 bar. The piston’s and cylinder head show no signs of detonation.
I have just had this bike on a dyno, with some strange results, because of the problems I have been having we started running the bike at low rpm with no wastegate, time after time the bike would start to show very lean stutter and stop running, restart, run for a couple of minutes, show very lean and stop running. Fuel pressure remains constant at 50psi, injector duty is fine, so is the pulse width.
Attached is a log file that shows a very strange BTDC ignition timing, this showed only once on the logs, 55 seconds in you can see the ignition advance BTDC advance which caused the motor to stop running, there is nothing in the map to explain why this happened. But, the engine failed the same way at least a dozen times.
I had a feeling that if the ignition module I was using was at fault, could the ignition advance the motor receives be different to what is shown on the log?
I changed the ignition module and re ran the bike, all now appears to be correct, the bike has ran on the dyno for over 1 hour with 10psi boost with no problems.
Has anyone else come across a similar problem?
