wasted spark with 8 coils. tips?
I'm totally new to motec, and am gathering all i need to start with the complete system.
So far i have on paper what i want, what i need, what i have, and still have to buy.
Now, the M800 has 6 ignition outputs.
I want to run wasted spark, but want to do this with 8 coils (a V8 Ford 460 engine)
At work i've ordered Omron Solid state relays of 10 amps each.
I want to drive 2 relays per one output, and have each relay itself switch a coil.
So, 2 coils are actuated on one output, and the output isn't overloaded by 2 coils.
Is this a good setup, or would anyone suggest to do this differently?
Don't know exactly how much current each coil would pull, so i thought 10 amps each would be more than enough.
What wire diameter would one use for coils, injectors, sensors, and other stuff?
Thanks!!
Thanks!!
