M800 --> SLM
M800 --> SLM
Postby Mazi on Tue Jun 22, 2010 7:24 pm
M800 CAN transfer rate to SLM is fixed to 50Hz and cannot be changed. Is it true?
Mazi
Re: M800 --> SLM
Postby RossB on Fri Jun 25, 2010 4:53 pm
If it is on CAN 1 Data you can set it to 33 Hz. What do you want to change it for?
Re: M800 --> SLM
Postby Mazi on Mon Jun 28, 2010 8:13 pm
Yes, I can set it to 33Hz, but M800 will send data to SLM in 20ms period.
I want to maintain CAN traffic as low as it is possible because of heavy load from some other devices connected to the same CAN. Just don't want to use CAN router to split the traffic in to two buses yet. I know that amount of data sent to SLM is unimportant, but however.
Mazi
