Minus Fuel Comp PW Table
I have an M800 with version 3 software.
Ideally I would like to create a negative/minus fuel comp table which would remove a fixed PW amount from the commanded fuel PW rather than removing a % of the commanded fuel PW.
In the nitrous section there are for example comp tables which will "add" a defined PW to a commanded pulse width.
Is it possible to create something like this but in reverse (ie: remove a fixed pulse width value from the commanded pulse width)?
The goal would be New PW = Old PW - "X" where "X" would be defined in the table. If not the current commanded PW, then at least the next.
Thanks.
Thanks.
