Drive by Wire not Active
Postby stevegibson on Thu Jun 17, 2010 8:25 am
I have just installed a 2008 engine and dbw throttle bodies into a 2006 R1 with a M800 on board and built a new loom for it (took about 4 weeks)
I just tried to upload a Map for the new throttle bodies but it says that Drive by Wire isn't active on the ECU.
I thought dbw was a standard module included on the M800, apparently not - Can someone advise if getting this activated will cost anything or if I just need to install a standard upgrade?
if it will cost - how much am I looking at?
Steve
stevegibson
Re: Drive by Wire not Active
Postby IJ. on Thu Jun 17, 2010 8:40 am
It's an Enable, depending on your location price may vary, mine from memory was under $400 AUD.
IJ.
