Park/In Gear input
Mon Jun 14, 2010 2:09 am
by F6R
Can an input be configured to add a fixed value of idle control duty cycle when the transmission is engaged into gear?
Re: Park/In Gear input
Mon Jun 14, 2010 9:03 am
by IJ.
Not sure if this is the "correct" way to do what you want but I'd look at the initial position table for the idle control and add a Y axis based on the switched input from the Trans selector and have it add/subtract some initial as needed.
Wed Jun 16, 2010 4:00 am
by F6R
Thanks I will have a go.
Wed Jun 16, 2010 4:10 am
by F6R
Cant get a Y axis up on any of the idle control tables.
What will work though is by using the power steering switch input and then the idle control set-up has that provision.
Wed Jun 16, 2010 7:36 am
by IJ.
Very strange I have X/Y axis on my Idle Normal Position table.
Which software/firmware are you running?
Thu Jun 17, 2010 5:41 am
by F6R
Am running 3.52J..........it's probably me.
Thu Jun 17, 2010 6:14 am
by IDP
When viewing the Idle normal position table hit the A key.
You will then have the dialog box to add the 3rd axis.
Wed Jun 30, 2010 12:15 am
by F6R
Thanks.
