Quick lambda and twin injectors
I have 2 injectors per cylinder on my M400, so both injectors always feed fuel. How does the ECU know this when using quick lambda. If Q/Lam thinks the A/F needs changing by 3% then it will change the pulsewidth to suit affecting both injectors so changing the fuelling by 6%.
Can I compersate for this.
Thanks.
Thanks.
