M400 and DBW throttle in Toyota 2ZZ engine (Lotus ExigeS).
Hello
I need some help in setup of DBW throttle in Toyota 2ZZ engine in Lotus ExigeS.
I am using M400.
DBW has 5 connectors: M+, M-, TP1, TP2, 0V and 5V.
TP1, TP2, 0V and 5V work fine.
I connected M+ to power and it is the only way it works.
M- is connected to MOTEC AV1 using function "DBW".
Accelerator pedal works fine - I can calibrate it (TPD1 and TPD2) as well as TP1 and TP2 on throttle body.
The problem is how to configure Motec to move throttle as I press accelerator pedal?
I can move throttle in "test outputs" mode. When I differ dutycycle from 10-20% I can open and close throttle "by wire".
I do not know what to put in Motec config and where to put it to make the throttle react on accelerator pedal. I tried to contact distributor, but it is hard to get anything.
Second problem is idle. As my throttle body does not have special connector for idle control. How to wire it to AV2 (it can be configured as DBW - idle control)?
Thanks in advance.
I am using M400.
Thanks in advance.
