Page 1 of 2
M800 Tacho output
Sat Jun 05, 2010 7:56 am
by Daniel
Hi
I am running a ls2 v8 with a M800 in a VS Commodore ute with the std dash.I want to get the std tacho working but
can not see why it wont work.
I am running the STD ls2 coils in wasted spark and engine goes well.I have wired the ing output #6
into the tach on the dash but i get nothing.
I have checked wiring and its all good.
This car used to run a holden 304 v8 with a std ignition system no worrys and it Tacho was hooked
up the - side on the coil and worked fine this way.
Is this something to do with the motec or do i need to add something to the wiring.
Thanks Daniel
Re: M800 Tacho output
Sat Jun 05, 2010 9:50 am
by IJ.
Tried using an AUX out in mode #4?
Sat Jun 05, 2010 10:14 am
by Daniel
No i havnt as yet, as i dont have any left but will try that tonight and see.
Thanks Daniel
Sat Jun 05, 2010 10:20 am
by IJ.
Daniel wrote:No i havnt as yet, as i dont have any left but will try that tonight and see.
Thanks Daniel
Can only use AUX 1>4 Dan.
Sat Jun 05, 2010 11:36 pm
by Daniel
Thanks mate i will try in the morning and let you know.
Thanks Daniel
Sun Jun 06, 2010 7:48 am
by IJ.
I use it here to send the RPM signal to my Trans controller and have used it in the past to run factory Tach's before I got the SDL.
Sun Jun 06, 2010 11:27 am
by Daniel
Nope no good. Moved some things around so i could use AUX3 an its the same i have nothing.
Any ideas?
Daniel
Sun Jun 06, 2010 2:34 pm
by IJ.
Currently I'm using Ign #6 in mode #4 to drive the tach in of my trans controller (LSx V8 in batch fire)
Not sure what signal the stock Tach is looking for though sorry.
Sun Jun 06, 2010 5:55 pm
by Daniel
Well the way its set up normally is run just from the - neg side of the coil straight to tacho.
I tryed my dash in another car this afternoon and worked fine so i know
the dash tacho is fine.I checked the wiring in my car as well by hooking the -side coil wire from the other
car to my wiring in the dash and aswell my dash tacho worked fine.
So i am sure this is a motec output thing and would like to know more info as what i would
have to do to fix this. Do i have to put a pull up resistor to 12Volts on the line to work?
HELP
Daniel
Sun Jun 06, 2010 9:26 pm
by IJ.
Not 100% sure but I thought the MoTeC Tach driver was a 5v square wave output (someone that knows might jump in to confirm)
I had an issue with a Toyota Tach some years ago and ended up taking it to an Instrument shop down here and they tweaked it up to work.
