UTC Firmware
UTC Firmware
Postby Mick on Mon May 24, 2010 5:03 pm
Some questions on firmware for the UTC being used with a M800.
There is nothing in the Manual.
(a) Is the UTC firmware different for each version of ECU firmware?
(b) When doing any ECU upgrade do you have to always upgrade the UTC firmware first?
(c) How can you tell what firmware the UTC already has?
(d) What are the UTC firmware versions for ECU firmware Versions 3.41G2 and 3.52P2?
Mick
Re: UTC Firmware
Postby MarkMc on Tue May 25, 2010 5:22 pm
The UTC software is installed with M800 software, it does not change that often. When you go to the start menu and to the programs and the UTC utility you will be able to see the version number, there is no real way of seeing what version is in you UTC.
Just keep an eye on this each time you download a new version of M800 software.
