m400 fly by wire throttle
Hi
I have a 1600 engine with a fly by wire barrel throttle body and m400 ecu.
How often should i have to calibrate the sensors.
I was at Philip Island on the weekend and had a problem with the engine cutting out.
When i was on full throttle the engine cut out so i pulled off the track and found that engine was still idling but with no throttle response.I turned the car off and back on again and everything was ok ,car ran good.
The next time i went out the problem occurred again at full throttle but this time before the car stopped the throttle came back so i kept going.The same thing happened again half a lap further on and the throttle came back again while i was rolling back to the pits with the engine idling.
The problems has gone by the time i get back to pits or when i restart the car and when i had look at the lap top there are no errors showing.
I don't know what to look for or it might be nothing to do with the fly by wire.
Could it be a calibration issue.
Any help would be appreciated.
Regards
Phil
Regards
Phil
