Bosch motorsport coil 0 221 604 014
Fri Aug 22, 2008 2:10 am
by toby
Does anyone have any experience running these coils with M800 series ECU's?
Re: Bosch motorsport coil 0 221 604 014
Mon Aug 25, 2008 12:51 pm
by RossB
We haven't done much in the way of testing but if it is settings you need:
Volts Dwell
6 10.0
8 5.8
10 3.6
12 2.6
14 2.1
16 1.8
Pin 1 ECU, Pin2, Ground, Pin3 Bat V.
Tue Aug 26, 2008 9:08 am
by stevesingo
Tue Aug 26, 2008 9:06 pm
by toby
Thanks guys. I had heared some reliability issues from MoTeC Aus via MoTeC Europe and am just specing some coils for a turbo suzuki engine.
Wed Aug 27, 2008 7:14 am
by stevesingo
Toby,
I'd be interested to hear any info on these as I was planning on using them on my BMW S14 (E30M3), running M800.
Steve
Thu Aug 28, 2008 11:35 pm
by toby
Events have overtaken me! There are no connector plugs currently available here from Bosch for this coil for at least 3 weeks. I will be using std Jap bike stick coils.
Fri Aug 29, 2008 6:08 am
by stevesingo
I know Swindon Race engines (UK) have recently fitted another S14 with these coils, you may want to give them a call.
What engine are you fitting them to. My plan B was VFR800VTEC Coils.
Steve
Fri Aug 29, 2008 9:16 pm
by toby
The Bosch coils were going on a turbo GSX1400 but as I said, I am now going to use std Jap stick coils from any of the modern Jap 1000cc bikes (non Cdi).
Sat Aug 30, 2008 7:43 am
by Apex Speed Tech
That's all you need. I've made 550hp at 40psi of boost on GSXR1300's bored out to 1600 using the stock coils.
Mon Jan 05, 2009 6:35 am
by Arve Flaat
Hello
Have used the coils and they work very well. The coil are not expensive and since the transistor is integrated in the coils it give very few wiers/easy wiering.
The connectors are:
Bosch: part nr D 261 205 367 and can be bought at
www.BSA-motorsport.deThe connector is made of Sumitomo. The part nr is: 6189-0779.
Regards
Arve Flaat
