Using Dig In 3 for switchable antilag?
I am currently using a momentary button on my steering wheel wired to Dig in 3 to activate antilag (function 13) but I would like to have two separate antilag settings. Currently I am using just the one antilag to rev the engine and create boost for the burnout and also to launch the car but I would like to use that steering wheel button to initiate a second antilag that is at a higher RPM and more ignition retard to create more boost before my burnout. I would like the first one to be active based only on the axis' that I am using in the cut table (Ground speed and RPM) and I would like when the momentary button is held down to use the information in cut table 2. I'm not sure how to set this up.
