Suzuki TL1000 bike engine CRIP
Thu Apr 08, 2010 8:43 pm
by ARE
Hi all,
I have a 100 series ecu to install on a Suzuki TL 1000 bike engine.Has anyone sat down and measured the crip for one of these engines as yet ? If not then i will advise of outcome once I have done it.The motor runs the standard ref / sync sensors in the standard locations as designed by Suzuki .
regards ARE
Re: Suzuki TL1000 bike engine CRIP
Thu Apr 15, 2010 7:21 am
by insomnia
TL1000S or TL1000S ?
Fri Apr 16, 2010 5:15 pm
by Martin
R?
insomnia wrote:Hi,
Fri Apr 16, 2010 10:26 pm
by insomnia
Hi Martin,
For sure you're right!! A little mistake from me
TL 1000S or TL 1000R .....
I know the main difference is S with 2 Injectors and
R with 4 Injectors....
Tue Apr 20, 2010 9:50 pm
by ARE
Hi Guys,
In answer to your question a TL1000S
regards A.R.E.
Thu Apr 22, 2010 2:16 pm
by MarkMc
Just remember, even if someone supplies a CRIP number you should always check it with a timing light. There are a number of manufacturers who change the crank/cam triggers to different positions depending on where the bike/car is sold. We have seen many people caught out with various Subaru engines where the CRIP is 40 degrees different even for the same basic engine configuration.
Fri Apr 23, 2010 6:34 pm
by Polux RSV
If I remember correctly, the TL motors (S and R) use 4 tooth, evenly spaced, no missing, with one longer than the 3 others. The 1st gen Aprilia V60 use the same scheme, but with 6 tooth.
Will the MX00 work with these schemes?
Angelo
Wed May 12, 2010 10:30 pm
by oit96
soory,i have a question ??
How to cancel cam sensor function ??
