Suzuki TL1000 bike engine CRIP
Postby ARE on Thu Apr 08, 2010 8:43 pm
Hi all,
I have a 100 series ecu to install on a Suzuki TL 1000 bike engine.Has anyone sat down and measured the crip for one of these engines as yet ? If not then i will advise of outcome once I have done it.The motor runs the standard ref / sync sensors in the standard locations as designed by Suzuki .
regards ARE
ARE
Re: Suzuki TL1000 bike engine CRIP
Postby insomnia on Thu Apr 15, 2010 7:21 am
TL1000S or TL1000S ?
insomnia
Postby Martin on Fri Apr 16, 2010 5:15 pm
R?
insomnia wrote:Hi,
Postby insomnia on Fri Apr 16, 2010 10:26 pm
Hi Martin,
For sure you're right!! A little mistake from me :-(
TL 1000S or TL 1000R .....
I know the main difference is S with 2 Injectors and
R with 4 Injectors....
insomnia
Postby ARE on Tue Apr 20, 2010 9:50 pm
Hi Guys,
In answer to your question a TL1000S
regards A.R.E.
ARE
Postby MarkMc on Thu Apr 22, 2010 2:16 pm
Just remember, even if someone supplies a CRIP number you should always check it with a timing light. There are a number of manufacturers who change the crank/cam triggers to different positions depending on where the bike/car is sold. We have seen many people caught out with various Subaru engines where the CRIP is 40 degrees different even for the same basic engine configuration.
Postby Polux RSV on Fri Apr 23, 2010 6:34 pm
If I remember correctly, the TL motors (S and R) use 4 tooth, evenly spaced, no missing, with one longer than the 3 others. The 1st gen Aprilia V60 use the same scheme, but with 6 tooth.
Will the MX00 work with these schemes?
Angelo
Polux RSV
Postby oit96 on Wed May 12, 2010 10:30 pm
soory,i have a question ??
How to cancel cam sensor function ??
oit96
