LS-1 with M800
We have M800 on a Chevy LS-1 engine with MSD crank trigger and original Sync sensor.
We've encountered problems in getting the engine running.
We have tried various settings, but the engine just seems back fire or burn gas in exhaust pipes. Sometimes it gets running with the same banging effects.
We have set the timing such that a traditional timing light shows 10 degrees of advance when craning the engine.
The firing order seems to be correct (18726543), also by measuring with the timing light from all the plug wires.
(Cylinders 1 & 6 show 10 deg., 8 & 5 show 280, etc.)
So has anybody got M800, LS-1 and crank trigger working?
And what is then the correct REF & Sync sensor set-up?
Does M800 require expander kit to work with LS-1?
Now we are using wasted spark & One Tooth Per Firing configuration.
Thanks,
Sakke
Thanks,
Sakke
