Hi
I am running the M800 with 2 x two channel Bosch ignition amplifier modules on a 2008 Yamaha R1 with standard coils.
I have been asked to pin out the coils and injectors in the order 1,2,4,3 to get the correct firing sequence - when I look at the motec ECU Manager this also has the firing sequence 1,2,4,3.
My question is, wouldn't the above be the same as pinning out the injectors and coils as 1,2,3,4 and then setting the Motec to 1,2,3,4?
Being new to this game, if someone could explain to me how the physical wiring of the ignition order relates to the software configuration I would appreciate it.
Many Thanks
Steve
