M800 M&W ignition issue
I am running a M800 with a M&W Pro-Drag6 ignition on a Toyota 2JZ engine. When we were on the dyno we were experiening issues with the ignition where we would get a misfire at ~8200 RPMs using the ignition in waste spark configuration. We are planning on switching the ignition to sequential in hopes to eleviate this problem.
Does anyone know if running this particular ignition in waste spark mode could cause us to overheat the coils or cause any other ignition issues? Do you think that switching to sequential might solve some of our issues.
Initially we thought it was an issue with coil dwell, and lowered the dwell from 2.2ms all the way to 0.1ms with improving results, but still experienced a misfire.
Any help would be appreciated
