Chopper Disks
Tue Mar 23, 2010 1:32 pm
by rx7brain
Does anyone know where or who makes a chopper disk with a OD of between 100mm - 110mm?
Or the CAD code so I can get one cut.
If I can find one that size I can run it behind the gilmer.
Re: Chopper Disks
Wed Mar 24, 2010 7:32 am
by figgie
What type of choper disk are you looking for?
I have attached the 60-2 and 36-1 dimensions, these where copied from Bosch (they are the inventors of it).
Re: Chopper Disks
Thu Mar 25, 2010 4:31 am
by Turby
You could try
http://www.emachineshop.com/ which allows you to design and draw what you want and then get the part made
Re: Chopper Disks
Sat Mar 27, 2010 8:26 pm
by rx7brain
Thanks Turby and Figgie.
Great info.
I ended up sourcing one nearly exactly the size I was after from a place in the UK, triggerwheels.com.
AU$45 delivered, figured that would be hard to beat.
That emachineshop concept is awesome, I will remember that.
