crimping tool
crimping tool
Postby snake on Thu Feb 25, 2010 5:56 pm
hey is there someone who can tell me what tool to name / number to Crimping pins for M400 ECU. Regards Henrik
snake
Re: crimping tool
Postby thorstengsxr on Fri Feb 26, 2010 6:03 pm
thorstengsxr
Re: crimping tool
Postby Scott@FP on Tue Mar 02, 2010 9:40 am
While this may not be the 100% *proper* tool, it will handle a WIDE variety of smaller terminals very well, and is very inexpensive;
Molex P/N 063811-1000
http://www.molex.com/molex/products/dat ... Lang=en-US
If you could only carry one crimp tool for your on-site crimping needs for open U style terminals this would be it.
Nothing beats the OEM proper tool, but sometimes you have to make do with what you have.
Re: crimping tool
Postby IJ. on Wed Mar 03, 2010 7:58 am
The 100 series connectors used need a tight roll on the insulation part of the crimp so they will fit in through the waterproof grommet, I got my crimper directly from MoTeC it was worth spending the $ and getting the right tool.
IJ.
Re: crimping tool
Postby figgie on Fri Mar 05, 2010 8:21 am
well the connector is an AMP connector which is now owned by Tyco electronics.
A tyco pro-crimper III with the correct die, DONE.
figgie
Re: crimping tool
Postby IJ. on Fri Mar 05, 2010 9:36 am
figgie wrote:well the connector is an AMP connector which is now owned by Tyco electronics.
That's what MoTeC supplied ;)
IJ.
Re: crimping tool
Postby snake on Sat Mar 06, 2010 5:43 am
hi and thanks for your responses. Regards Henrik
snake
