User Defined Sensors 2.3 software Problem
Hey Guys,
I've downgraded to 2.3 software, but I cannot seem to have my user defined lambda and EGT sensors working.
The 3.5 software is very easy to setup user defined sensors with a calibration table.
I cant seem to do the same in the 2.3 software. I have AV6 and AV7 setup for Lambda and EGT respectively and I have them as user defined channels, however I cant seem to enter a voltage vs lambda or egt value in the table.
The table is deg C vs an arbitrary value, which seems to be the signal voltage coming from the sensors when the data is live?
How can I setup a voltage vs value calibration in 2.3 software , similar to the 3.5 setup or at least to get the sensors working.
