MoTeC USB and 64 bit windows
Re: MoTeC USB and 64 bit windows
Postby Busadk on Thu May 05, 2011 6:49 pm
Hi
I have a new laptop now and can make the MoTeC work with windows 7 64bit after installing the small add. Program for 64bit
The I2 works as well until you have to look at the engine health, all the channels just show N/A
Is there a trick as well or do i have to find my old laptop with XP or go 32bit?
Regards
Busadk
Postby Martin on Fri May 06, 2011 1:26 am
Are you looking at the graphs vs time or distance?
If you dont have a speed/distance channel and you want to view graphs agains distance it will show NA
press F9 to toggle between the time and distance
Postby Busadk on Sat May 07, 2011 4:02 am
Hi Martin
If i could find out how to put in pic. I could show you.
I2 open then dragrace, then you have options EGTs, Drive Line, Fuel and then comes Engine helth... and it just show nothing....
But if i take my ols laptop with XP everything is there, so i think it has something to do with me using 64 bit on the new one...
Mogens
Busadk
Postby Martin on Tue May 10, 2011 2:30 am
When you see the graph....is it time or distance at the bottom?
I use 64bit, it works OK for me
Press F9 to toggle between time and distance.
See the picture to know what it is...time or distance. If you dont have a distance channel nothing will show
