Variable vane geometry turbo
Re: Variable vane geometry turbo
Postby Martin on Mon Jun 01, 2009 8:53 pm
Thank you very much for the information. Its greatly appreciated!
May I have your email address to send you some information as i progress? You can send it via PM.
regards
Postby Martin on Wed Jun 03, 2009 4:45 pm
Hi SportsCarRacer
If I understand you corectly the GTxxyyV is the Dutycycle type and the GTBxxyyVK is the type where the ECU drives the DC servo Directly?
Is this the "povvo" type?
Postby DarrenR on Tue Nov 24, 2009 1:13 pm
Martin sent this actuator to us at Motec.
i've been able to figure it out!
It works on 300Hz (290 to 310Hz) and duty = position from 5% to 90%.
Pin 1 (round end) +12v
Pin 2 Ground
Pin 3 N/C
Pin 4 Signal
Pin 5 N/C
The signal pin has a pull up to 12v built in so just needs connecting directly to a switch to ground output.
Easy to operate with a dash or ECU. It would be interesting to see how well a VNT turbo works!
Darren Reynolds
DarrenR
Postby Martin on Tue Nov 24, 2009 9:56 pm
It just took him a single arvo :D
Thanks for the help Darren, Ill get a job for that VNT as soon as its back
Postby DarrenR on Fri Nov 27, 2009 9:23 am
I had help from SportsCar Racer! And i was about to give up, last attempt was just to throw a bunch of different frequencies at it,as i didn't know if it was CAN of freq control, or what the pin out was, so i was just lucky.
Darren Reynolds
DarrenR
Postby karel021 on Mon Apr 15, 2019 10:52 pm
Bump !!
Did you figure it out ?
i have a porsche 997 turbo that has this variable actuators.
just 12v,gnd and pulse them with an input?
karel021
